Are you looking for Maui-LX Burgundy and Tan Right Motor with Remote 20 Ft. Wide x 10 Ft. Projection Retractable Awning? We found best price for you. Go to link below to buy the Maui-LX Burgundy and Tan Right Motor with Remote 20 Ft. Wide x 10 Ft. Projection Retractable Awning for the lowest price.
Maui-LX Burgundy and Tan Right Motor with Remote 20 Ft. Wide x 10 Ft. Projection Retractable Awning Review
This is my first Awntech Corp product and I'm really satisfied with it. I cant find better for the price of 2639.93.
Maui-LX Burgundy and Tan Right Motor with Remote 20 Ft. Wide x 10 Ft. Projection Retractable Awning Description
- Beauty-Mark brand Maui-LX model motorized retractable awning - Manual over-ride motor with remote control. Right motor when facing the awning - 20' wide x 10' projection or depth with adjustable pitch - Multi chamber arms with stainless steel cables - Structural steel and aluminum frame, powder coated in white - Fade, mildew, water resistant 100% solution dyed acrylic fabrics - 10 Sahara style valance with off-white trim - Fully assembled, ready to install and comes with the wall brackets - 5 year limited warranty - Product Depth: 120 - Product Width: 240 - Product Height: 10 - Product Weight: 189 - Material: Fabric - Minimum Mount Height: 96-in - Minimum Required Clearance: 10-in - Includes Fully assembled awning, product manual, rocker arm, wall mount brackets, and remote control Awntech Corp - MTR20-398-BTM
Related posts
- Maui-LX Burgundy Pin Right Motor with Remote 24 Ft. Wide x 10 Ft. Projection Retractable Awning
- Maui-LX Burgundy and Tan Right Motor with Remote 16 Ft. Wide x 10 Ft. Projection Retractable Awning
- Maui-LX Burgundy Pin Right Motor with Remote 18 Ft. Wide x 10 Ft. Projection Retractable Awning
- Maui-LX Burgundy Right Motor with Remote 24 Ft. Wide x 10 Ft. Projection Retractable Awning
- Maui-LX Burgundy Pin Right Motor with Remote Retractable 12 Ft. Wide x 10 Ft. Projection Awning
- Maui-LX Burgundy Right Motor with Remote Retractable 12 Ft. Wide x 10 Ft. Projection Awning
- Maui-LX Burgundy Pin Right Motor with Remote 8 Ft. Wide x 7 Ft. Projection Retractable Awning
- Maui-LX Burgundy and Tan Right Motor with Remote 24 Ft. Wide x 10 Ft. Projection Retractable Awning
- Maui-LX Burgundy and Tan Right Motor with Remote 8 Ft. Wide x 7 Ft. Projection Retractable Awning
- Maui-LX Burgundy Right Motor with Remote 8 Ft. Wide x 7 Ft. Projection Retractable Awning
- Maui-LX Burgundy and Tan Right Motor with Remote 18 Ft. Wide x 10 Ft. Projection Retractable Awning
- Maui-LX Burgundy Pin Right Motor with Remote 14 Ft. Wide x 10 Ft. Projection Retractable Awning
- Maui-LX Burgundy and Tan Right Motor with Remote Retractable 12 Ft. Wide x 10 Ft. Projection Awning
- Maui-LX Burgundy Pin Right Motor with Remote Retractable 10 Ft. Wide x 8 Ft. Projection Awning
- Maui-LX Burgundy Right Motor with Remote 18 Ft. Wide x 10 Ft. Projection Retractable Awning
- Maui-LX Burgundy Pin Left Motor with Remote 24 Ft. Wide x 10 Ft. Projection Retractable Awning
